跳转到主内容
Asus F555LA-AB31 Battery Replacement
你所需要的
  1. Asus F555LA-AB31 Battery Replacement, CD Drive: 步骤 1 中的图像 1,1
    • Turn off and unplug the device before starting repairing.
    • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
  2. Asus F555LA-AB31 Battery Replacement: 步骤 2 中的图像 1,2 Asus F555LA-AB31 Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the laptop over and flip the screen up.
    • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
  3. Asus F555LA-AB31 Battery Replacement: 步骤 3 中的图像 1,1
    • Disconnect the keyboard flex cable from its motherboard ZIF socket.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  4. Asus F555LA-AB31 Battery Replacement: 步骤 4 中的图像 1,2 Asus F555LA-AB31 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
    • Slowly slide out the CD drive, keeping it level, to remove it.
  5. Asus F555LA-AB31 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Asus F555LA-AB31 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the four 4 mm Phillips #0 screws securing the battery.
  6. Asus F555LA-AB31 Battery Replacement: 步骤 6 中的图像 1,2 Asus F555LA-AB31 Battery Replacement: 步骤 6 中的图像 2,2
    • Lift up battery and remove it from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 29
总计 4,374
