跳转到主内容
加入维修社区 - 创建账户
Asus Eee PC 900 SSD Replacement
你所需要的
    1. Asus Eee PC 900 SSD Replacement, Battery: 步骤 1 中的图像 1,3 Asus Eee PC 900 SSD Replacement, Battery: 步骤 1 中的图像 2,3 Asus Eee PC 900 SSD Replacement, Battery: 步骤 1 中的图像 3,3
      • Slide the battery's locking tabs from the locked position to unlocked positions.
      • The right tab is unlocked when a red dot is showing.
      • The left tab will have to be held in the unlocked position in order to release the battery.
      询问修复机器人
      添加评论
    2. Asus Eee PC 900 SSD Replacement: 步骤 2 中的图像 1,1
      • Slide the battery out while holding the left locking tab in the unlocked position.
      添加评论
    1. Asus Eee PC 900 SSD Replacement, SSD: 步骤 3 中的图像 1,3 Asus Eee PC 900 SSD Replacement, SSD: 步骤 3 中的图像 2,3 Asus Eee PC 900 SSD Replacement, SSD: 步骤 3 中的图像 3,3
      • Remove the small sticker on the right side of the SSD/RAM compartment cover.
      • Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
      询问修复机器人
      添加评论
    2. Asus Eee PC 900 SSD Replacement: 步骤 4 中的图像 1,2 Asus Eee PC 900 SSD Replacement: 步骤 4 中的图像 2,2
      • Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
      • Lift the cover away from the laptop.
      询问修复机器人
      添加评论
    3. Asus Eee PC 900 SSD Replacement: 步骤 5 中的图像 1,3 Asus Eee PC 900 SSD Replacement: 步骤 5 中的图像 2,3 Asus Eee PC 900 SSD Replacement: 步骤 5 中的图像 3,3
      • Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
      • When the screws are removed, one end of the SSD should pop up.
      • Slide the SSD out of its socket and lift it out of the compartment.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
Brian Carreon
于01/25/12注册
300 声望
创作了2篇指南
团队
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G27
4 名成员
创作了72篇指南
5指南评论
What for specifications do the SSD has? I want to replace, too but do not know the execactly specs. I bought a 30GB m-sata ssd and this is not accepted by bios and does not work.
Marcus - 回复 分享
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
adrien - 回复 分享
There are now miniPCIe mSATA adapters. I plan to try this.
ejolson - 回复 分享
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
Andre De Guerin - 回复 分享
what kind of adapter you use? My ssd died….
rui fontes - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 28
过去 30 天: 92
总计 46,697
