跳转到主内容
加入维修社区 - 创建账户
Asus Eee PC 1008ha Screen Replacement
你所需要的
    1. Asus Eee PC 1008ha Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Using the plastic opening tool, carefully pry the top panel from the base.
      询问修复机器人
      添加评论
    2. Asus Eee PC 1008ha Screen Replacement: 步骤 2 中的图像 1,3 Asus Eee PC 1008ha Screen Replacement: 步骤 2 中的图像 2,3 Asus Eee PC 1008ha Screen Replacement: 步骤 2 中的图像 3,3
      • Lift the side of the keyboard.
      • Disconnect the attached ribbon located underneath the keyboard.
      • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
      询问修复机器人
      添加评论
    3. Asus Eee PC 1008ha Screen Replacement: 步骤 3 中的图像 1,2 Asus Eee PC 1008ha Screen Replacement: 步骤 3 中的图像 2,2
      • Use your fingers to lift the battery and gently disconnect the wires from the base.
      询问修复机器人
      添加评论
    1. Asus Eee PC 1008ha Screen Replacement, LCD Screen: 步骤 4 中的图像 1,2 Asus Eee PC 1008ha Screen Replacement, LCD Screen: 步骤 4 中的图像 2,2
      • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
      • Carefully pull the circuit board away from side of device base.
      询问修复机器人
      添加评论
    2. Asus Eee PC 1008ha Screen Replacement: 步骤 5 中的图像 1,3 Asus Eee PC 1008ha Screen Replacement: 步骤 5 中的图像 2,3 Asus Eee PC 1008ha Screen Replacement: 步骤 5 中的图像 3,3
      • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
      • Gently lift the screen portion from the base.
      询问修复机器人
      添加评论
    3. Asus Eee PC 1008ha Screen Replacement: 步骤 6 中的图像 1,2 Asus Eee PC 1008ha Screen Replacement: 步骤 6 中的图像 2,2
      • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
      • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
      询问修复机器人
      添加评论
    4. Asus Eee PC 1008ha Screen Replacement: 步骤 7 中的图像 1,2 Asus Eee PC 1008ha Screen Replacement: 步骤 7 中的图像 2,2
      • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
      询问修复机器人
      添加评论
    5. Asus Eee PC 1008ha Screen Replacement: 步骤 8 中的图像 1,2 Asus Eee PC 1008ha Screen Replacement: 步骤 8 中的图像 2,2
      • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
      • Use your fingers to hold the screen and carefully lift it from the base.
      询问修复机器人
      添加评论
    6. Asus Eee PC 1008ha Screen Replacement: 步骤 9 中的图像 1,2 Asus Eee PC 1008ha Screen Replacement: 步骤 9 中的图像 2,2
      • Use your fingers to peel back the adhesive tape located on the back of the screen.
      • Disconnect the wire from the screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G52
4 名成员
创作了36篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 36
总计 3,535
