跳转到主内容
加入维修社区 - 创建账户
Asus Eee PC 1000HE Keyboard Replacement
你所需要的
  1. Asus Eee PC 1000HE Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop down with the bottom facing upwards.
    • Locate the two battery lock slide tabs.
    询问修复机器人
    添加评论
  2. Asus Eee PC 1000HE Keyboard Replacement: 步骤 2 中的图像 1,2 Asus Eee PC 1000HE Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the tabs outward to unlock the battery.
    • The right tab will remain in the unlocked position while the left tab must be held.
    • While holding the left tab outward, slide the battery away from you to remove it.
    询问修复机器人
    添加评论
  3. Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • The keyboard will still be attached to the body of the netbook at the conclusion of this step through a ribbon cable located at the bottom edge of the keyboard. Improper removal may result in damage to your device.
    • Identify the four connection points holding the top of the keyboard to the main body of the netbook. To remove the keyboard, use the spudger to unhook the keyboard upwards at these points.
    • The keyboard will become more disconnected as you use the spudger at each connection point.
    添加评论
  4. Asus Eee PC 1000HE Keyboard Replacement: 步骤 4 中的图像 1,3 Asus Eee PC 1000HE Keyboard Replacement: 步骤 4 中的图像 2,3 Asus Eee PC 1000HE Keyboard Replacement: 步骤 4 中的图像 3,3
    • Flip the keyboard over by pulling the top edge of the keyboard away from the netbook body, using the bottom edge as a hinge point.
    • Locate the opaque strip, or ribbon cable, connecting the back of the keyboard to the hardware of the netbook.
    • To disconnect the ribbon cable, use a plastic opening tool to pull each side of the black plastic strip, located below the ribbon cable, away from the ribbon cable.
    • The black strip will disconnect completely from the ribbon cable. The keyboard will then be detached from the netbook's body and can be safely removed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Mike Glenn
于03/21/16注册
1,026 声望
创作了8篇指南
团队
Clemson, Team 6-2, Benson Spring 2016 Clemson, Team 6-2, Benson Spring 2016 的会员
CLEM-BENSON-S16S6G2
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 1,432
