跳转到主内容
加入维修社区 - 创建账户
Asus 1015E-DS03 Screen Replacement
你所需要的
    1. Asus 1015E-DS03 Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Hold the laptop using both hands with the battery facing upwards.
      添加评论
    2. Asus 1015E-DS03 Screen Replacement: 步骤 2 中的图像 1,1
      • Push the two tabs located below the battery in towards each other using your thumbs.
      添加评论
    3. Asus 1015E-DS03 Screen Replacement: 步骤 3 中的图像 1,1
      • Push the battery upwards and out of the laptop as shown.
      添加评论
    4. Asus 1015E-DS03 Screen Replacement: 步骤 4 中的图像 1,1
      • Continue to push the battery upwards until it is completely separated from the laptop as shown.
      添加评论
    1. Asus 1015E-DS03 Screen Replacement, Front Screen Case: 步骤 5 中的图像 1,1
      • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
      • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
      询问修复机器人
      添加评论
    2. Asus 1015E-DS03 Screen Replacement: 步骤 6 中的图像 1,2 Asus 1015E-DS03 Screen Replacement: 步骤 6 中的图像 2,2
      • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
      • You will hear popping noises which are to be expected.
      询问修复机器人
      添加评论
    3. Asus 1015E-DS03 Screen Replacement: 步骤 7 中的图像 1,1
      • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
      询问修复机器人
      添加评论
    1. Asus 1015E-DS03 Screen Replacement, Screen: 步骤 8 中的图像 1,1
      • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
      询问修复机器人
      添加评论
    2. Asus 1015E-DS03 Screen Replacement: 步骤 9 中的图像 1,2 Asus 1015E-DS03 Screen Replacement: 步骤 9 中的图像 2,2
      • Lift the screen away from the computer.
      • Be careful removing the screen, as the left side is still connected to the computer.
      询问修复机器人
      添加评论
    3. Asus 1015E-DS03 Screen Replacement: 步骤 10 中的图像 1,2 Asus 1015E-DS03 Screen Replacement: 步骤 10 中的图像 2,2
      • Remove the wire that is glued to the back of the screen with your fingers.
      • Remove the tape covering the connection port.
      询问修复机器人
      添加评论
    4. Asus 1015E-DS03 Screen Replacement: 步骤 11 中的图像 1,1
      • Separate the screen from the computer by gently pulling it out.
      询问修复机器人
      添加评论
    5. Asus 1015E-DS03 Screen Replacement: 步骤 12 中的图像 1,1
      • Upon removal, the computer should look like this picture.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Becca Day
于03/23/16注册
321 声望
创作了2篇指南
团队
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G4
5 名成员
创作了49篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 1,126
