跳转到主内容
加入维修社区 - 创建账户
Astro A20 Microphone Replacement
你所需要的
    1. Astro A20  Microphone Replacement, Cushion: 步骤 1 中的图像 1,1
      • Place one hand on the hard side of the headset ear portion and on the cushion.
      • Lift the small portion on the edge of the cushion.
      询问修复机器人
      添加评论
    2. Astro A20  Microphone Replacement: 步骤 2 中的图像 1,1
      • Slide the metal spudger underneath the lift part of the ear cushion.
      • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
      添加评论
    3. Astro A20  Microphone Replacement: 步骤 3 中的图像 1,2 Astro A20  Microphone Replacement: 步骤 3 中的图像 2,2
      • Remove the ear cushion from the headset.
      添加评论
    1. Astro A20  Microphone Replacement, Microphone: 步骤 4 中的图像 1,1
      • Place one hand on the back of the speaker.
      询问修复机器人
      添加评论
    2. Astro A20  Microphone Replacement: 步骤 5 中的图像 1,2 Astro A20  Microphone Replacement: 步骤 5 中的图像 2,2
      • Remove the four 7mm screws with a Phillips #1 screwdriver.
      • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
      询问修复机器人
      添加评论
    3. Astro A20  Microphone Replacement: 步骤 6 中的图像 1,2 Astro A20  Microphone Replacement: 步骤 6 中的图像 2,2
      • Lift the speaker area.
      • Disconnect the wires that connect the microphone.
      • Remove the 7mm screw with a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
5指南评论
worked for me….thanks
Thompson Crusher - 回复 分享
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - 回复 分享
were? are you getting the new mic from? please link the site
jrod6t9 - 回复 分享
Zuppara - 回复 分享
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 113
总计 15,783
