跳转到主内容
加入维修社区 - 创建账户
Astak Mole Motherboard Replacement
你所需要的
    1. Astak Mole Motherboard Replacement, Lower Case: 步骤 1 中的图像 1,1
      • Remove the four bottom tabs in order to access the bottom screws.
      询问修复机器人
      添加评论
    2. Astak Mole Motherboard Replacement: 步骤 2 中的图像 1,1
      • Remove all four 14 mm Phillips #1 screws.
      添加评论
    3. Astak Mole Motherboard Replacement: 步骤 3 中的图像 1,1
      • Remove the SD card.
      询问修复机器人
      添加评论
    4. Astak Mole Motherboard Replacement: 步骤 4 中的图像 1,1
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      询问修复机器人
      添加评论
    5. Astak Mole Motherboard Replacement: 步骤 5 中的图像 1,1
      • Gently pull back the motherboard to expose many of the component's wired connections.
      添加评论
    1. Astak Mole Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Astak Mole Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
      • Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
      • All wired connections to the motherboard are removed by the thin plastic male connector inserted into the larger female plastic connection.
      询问修复机器人
      添加评论
    2. Astak Mole Motherboard Replacement: 步骤 7 中的图像 1,2 Astak Mole Motherboard Replacement: 步骤 7 中的图像 2,2
      • The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
      • Be careful not to scratch the CPU in this step. This is not a wired connection.
      • Sever the additional adhesive connections so that the wired connections may be removed.
      询问修复机器人
      添加评论
    3. Astak Mole Motherboard Replacement: 步骤 8 中的图像 1,1
      • Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
      • Screw Measurements: (Length= 5.3mm)
      询问修复机器人
      添加评论
    4. Astak Mole Motherboard Replacement: 步骤 9 中的图像 1,2 Astak Mole Motherboard Replacement: 步骤 9 中的图像 2,2
      • Remove the last two wired connections to the motherboard by severing the indicated connections.
      • Lift up the secondary motherboard as indicated using the metal spudger.
      • All connections should be severed from the motherboard and a new motherboard may be inserted.
      • It is advised to reapply adhesive to wired connections during reassembly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Andrew Birch
于09/15/16注册
204 声望
创作了2篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 944
