跳转到主内容
加入维修社区 - 创建账户
Astak Mole Camera Head Replacement
你所需要的
  1. Astak Mole Camera Head Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the four bottom tabs in order to access the bottom screws.
    询问修复机器人
    添加评论
  2. Astak Mole Camera Head Replacement: 步骤 2 中的图像 1,1
    • Remove all four 14 mm Phillips #1 screws.
    添加评论
  3. Astak Mole Camera Head Replacement: 步骤 3 中的图像 1,1
    • Remove the SD card.
    询问修复机器人
    添加评论
  4. Astak Mole Camera Head Replacement: 步骤 4 中的图像 1,1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    询问修复机器人
    添加评论
  5. Astak Mole Camera Head Replacement: 步骤 5 中的图像 1,1
    • Gently pull back the motherboard to expose many of the component's wired connections.
    添加评论
  6. Astak Mole Camera Head Replacement, Camera Head: 步骤 6 中的图像 1,1
    • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
    • Screw measurements: Length=7.0mm.
    • The third screw can be exposed by rotating the camera head.
    • Do not force the camera head farther than it will allow you.
    询问修复机器人
    添加评论
  7. Astak Mole Camera Head Replacement: 步骤 7 中的图像 1,1
    • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
    • Screw measurements: Length=3.5mm
    询问修复机器人
    添加评论
  8. Astak Mole Camera Head Replacement: 步骤 8 中的图像 1,3 Astak Mole Camera Head Replacement: 步骤 8 中的图像 2,3 Astak Mole Camera Head Replacement: 步骤 8 中的图像 3,3
    • Separate the three indicated outputs from the motherboard with metal spudger.
    • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
    询问修复机器人
    添加评论
  9. Astak Mole Camera Head Replacement: 步骤 9 中的图像 1,1
    • Separate the wire from CPU by cutting adhesive with metal spudger.
    • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
    • Be careful not to damage the CPU in the process. This is not a wired connection.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Bryan
于09/15/16注册
104 声望
撰写一个指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 26
总计 899
