跳转到主内容
加入维修社区 - 创建账户
Archos 5 Screen Replacement
你所需要的
    1. Archos 5 Screen Replacement, Screen: 步骤 1 中的图像 1,1
      • Please be sure that your device is powered off before attempting any repairs.
      • Please be aware that any further steps could possibly void the warranty of your Archos 5.
      询问修复机器人
      添加评论
    2. Archos 5 Screen Replacement: 步骤 2 中的图像 1,2 Archos 5 Screen Replacement: 步骤 2 中的图像 2,2
      • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
      • Use the screwdriver(PH000) to remove the screws located under the pads.
      • Lift the stand in order to get to the fourth screw.
      询问修复机器人
      添加评论
    3. Archos 5 Screen Replacement: 步骤 3 中的图像 1,2 Archos 5 Screen Replacement: 步骤 3 中的图像 2,2
      • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
      • Once all sides of the device are pried open, gently open the device .
      • Be careful not to tear the foil which connects the LCD screen to the motherboard!
      询问修复机器人
      添加评论
    4. Archos 5 Screen Replacement: 步骤 4 中的图像 1,2 Archos 5 Screen Replacement: 步骤 4 中的图像 2,2
      • Once you have opened your device, fold the screen away from the battery.
      • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
      • Use a plastic spudger instead of a metal spudger!
      询问修复机器人
      添加评论
    5. Archos 5 Screen Replacement: 步骤 5 中的图像 1,2 Archos 5 Screen Replacement: 步骤 5 中的图像 2,2
      • Using the plastic opening tool, lift the touch pad away from the cracked screen
      • Be careful not to pull or tear the small film/wires as shown in the picture. These are vital to connecting the glass screen and the LCD screen.
      询问修复机器人
      添加评论
    6. Archos 5 Screen Replacement: 步骤 6 中的图像 1,2 Archos 5 Screen Replacement: 步骤 6 中的图像 2,2
      • Lift the cracked screen off of your Archos 5 using the regular plastic spudger.
      • Be careful not to rip or tear the film connecting the glass screen and the LCD screen.
      询问修复机器人
      添加评论
    7. Archos 5 Screen Replacement: 步骤 7 中的图像 1,1
      • Peel the plastic screen away from your shattered glass screen, and replace with your new glass screen.
      • The film connecting the glass screen and the LCD screen is attached the plastic and will peel away with it. Be careful not to rip or tear it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 2,633
