跳转到主内容
加入维修社区 - 创建账户
Archos 101 G9 Flash Memory Replacement
你所需要的
  1. Archos 101 G9 Flash Memory Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
    询问修复机器人
    添加评论
  2. Archos 101 G9 Flash Memory Replacement: 步骤 2 中的图像 1,2 Archos 101 G9 Flash Memory Replacement: 步骤 2 中的图像 2,2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
    询问修复机器人
    添加评论
  3. Archos 101 G9 Flash Memory Replacement: 步骤 3 中的图像 1,2 Archos 101 G9 Flash Memory Replacement: 步骤 3 中的图像 2,2
    • Gently remove both ribbon cables from their sockets on the motherboard.
    询问修复机器人
    添加评论
  4. Archos 101 G9 Flash Memory Replacement: 步骤 4 中的图像 1,1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
    询问修复机器人
    添加评论
  5. Archos 101 G9 Flash Memory Replacement: 步骤 5 中的图像 1,1
    • Remove the display assembly from the back panel.
    询问修复机器人
    添加评论
  6. Archos 101 G9 Flash Memory Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  7. Archos 101 G9 Flash Memory Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the ribbon cable from its socket on the motherboard.
    询问修复机器人
    添加评论
  8. Archos 101 G9 Flash Memory Replacement: 步骤 8 中的图像 1,1
    • Remove the tape covering all of the solder connections on the motherboard.
    询问修复机器人
    添加评论
  9. Archos 101 G9 Flash Memory Replacement: 步骤 9 中的图像 1,1
    • Desolder all six of the connections that were underneath the tape.
    询问修复机器人
    添加评论
  10. Archos 101 G9 Flash Memory Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard from the tablet.
    询问修复机器人
    添加评论
  11. Archos 101 G9 Flash Memory Replacement, Flash Memory: 步骤 11 中的图像 1,1
    • Flip the motherboard around to the backside and pry off the silver covering using a nylon spudger.
    询问修复机器人
    添加评论
  12. Archos 101 G9 Flash Memory Replacement: 步骤 12 中的图像 1,1
    • Remove the largest black rectangle using the Hakko microsoldering kit.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Deneille Davids
于10/28/21注册
181 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G1
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 39
总计 571
