跳转到主内容
加入维修社区 - 创建账户
此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
Apple Wireless Keyboard 电池更换
浏览量: 12万
浏览统计数据:
过去24小时
20
过去 7 天:
121
过去 30 天:
522
总计
122,848
评论: 8
3 comments on steps, 5 guide comments.
Go to guide comments
已完成: 35
35 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 20
20 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 1 - 2 分钟
难度: 简单
特色指南
iFixit的工作人员认为该指南特别酷。
社区贡献指南
我们社区的一个非常棒的成员制作了本指南。它不是由 iFixit 工作人员创建的。
本指南展示了如何更换 Apple Wireless Keyboard 的电池。
你所需要的
工具
    1. Apple Wireless Keyboard 电池更换, 电池: 步骤 1 中的图像 1,1
      • 使用硬币拆下电池仓盖板。
      添加评论
    2. Apple Wireless Keyboard 电池更换: 步骤 2 中的图像 1,2 Apple Wireless Keyboard 电池更换: 步骤 2 中的图像 2,2
      • 将两节(上一代为三节)替换电池滑入电池仓。请确认电池端子的正负极方向正确。
      添加评论
结论
要重新组装设备,请按相反顺序执行这些说明。
取消:我没有完成这个指南。
35等其他人完成本指南。
作者
与
rab777hp
于11/17/09注册
20,420 声望
创作了3篇指南
团队
OPEN OPEN 的会员
Community
90 名成员
创作了120篇指南
5指南评论
This works great - as long as the batteries inside did not leak and create a permanent seal for the cap. I managed to get the keyboard working again by removing the batteries through the electronics compartment (remove grey center cover, slide electronics out). It did take some effort (including driving a screw into the stuck battery and yanking it out with pliers) to remove the stuck batteries and all the remains of the leakage, but I ended up with a working keyboard. Only thing is that I need to use the 'backdoor' every time my batteries need replacing, since the battery cover is permanently sealed...
Otto - 回复 分享
Also have a perma sealed battery cover. Poured vinegar in from middle and let soak over night. Wanna drill into coin slot to try and remove cover but need to get batteries out first. Can I just remove the one screw from logic board and disconnect ribbon cable, to have it slide out the power button end? How careful w cable? Looks like it has 2 tiny clips, do these need to be addressed or can I just pry it off?
William Shouse - 回复 分享
Warm the area where battery screw cover is in a stream of hot water from the faucet. Be careful not to get water into the keyboard or keys. The warmth will sometimes expand the aluminum enough to loosen the screw cover. Worked for mine.
Greg M - 回复 分享
Thanks!
worked well. Had to push old battery out from electronics cover area. Keyboard working again :)
tankapoet - 回复 分享
It’s possible, but how can I get it? I am in somali country please help me
saalix49 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 121
过去 30 天: 522
总计 122,848
