跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Apple Watch Series 2 Force Touch 垫圈更换
你所需要的
  1. Apple Watch Series 2 Force Touch 垫圈更换, 打开显示屏: 步骤 1 中的图像 1,1
    • 准备iOpener,并加热显示屏以软化粘合剂,将其固定到位。
    I have heated up the iOpener to 165 degrees and left it on for more than a minute. No way I can lift the screen off with the exact knife. Tried different angles in various places, but no go. I also used a hair dryer un til the watch screen was too hot to touch and even tried a very hard cutting tool blade and also no go. Could n ever get the blade under the face I applied enough force where I could see that the blade left small marks, not very big, but could never get anything to move or lift. What am I doing wrong? I spent 47 years at a global computer company and I am used to taking apart small things and applying force when required. I don’t know what I am doing wrong. Please help me.
    Rafael Blanco - 回复
    Getting the initial gap is not easy. Maybe a playing card could work its way in the tiny gap and cut some adhesive. After that there might be some success with an exacto knife. Or you want to try a piece of aluminum foil (folded for more rigidity) for cutting the adhesive. Be aware of the force touch gasket and that it might get damaged during that procedure.
    Tobias Isakeit -
    I finally used a hot air gun set to 150 deg. C heating up the edges by slowly spinning the watch around before the technique worked. Difficult is the level noted and it’s correct. Finally worked and watch perfectly functioning.
    Chris Giavotto - 回复
    I used a heat gun, too. I was worried after reading comments that it would burn up the LCD, so I heated it a little bit at a time, rotating it like you did, and checking to see if I could get my knife under it. I must have hit one of the buttons because it did turn on, but that did reassure me that the display was okay.
    It's open. Now that the watch and I have had a few minutes to cool down, I'm ready for the next step. Not as difficult as I thought it could be. Tomorrow, I'll be replacing the battery in an iPod Touch 6th Gen.
    bester -
    I had to heat the iOpener 2 times and leave it on top of the watch for 10 minutes.
    Axel Trujillo - 回复
  2. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 2 中的图像 1,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 2 中的图像 2,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 2 中的图像 3,3
    • 始终保持手指完全远离刀。 千万不要施加太大的压力,因为这可能会导致刀滑动并切割或损坏手表。
    • 仅将刀片的细边插入间隙,然后朝您的方向倾斜刀片以加宽间隙,并将显示屏略微抬起。
    • 将弯曲刀片的边缘放入显示器和外壳之间的薄间隙中。 从显示屏的短边开始,最靠近圆形圈。
    • 不要将刀插入1/16英寸(约2毫米)。
    It’s difficult to grip case in a way that keeps fingers safe from the blade but doesn’t hit the side buttons and turn the device on!
    If it’s a struggle to get the display to release, warm case for a few more minutes.
    Kyle Powderly - 回复
    I have tried so may times to get the display to release but nothing works. Should have bought a new watch LOL. Kept the iOpener on 2 times for 10 minutes and it still won't open. There must be a better way.
    Susan E. White - 回复
    Hi Susan,
    if you're struggling to get the adhesive loose enough a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Dominik Schnabelrauch -
  3. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 3 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 3 中的图像 2,2
    • 一旦使用刀片打开了小间隙,请移除刀片并将打开工具的较薄边缘插入间隙中。
    • 在此插入翻译将开口工具推入间隙,用拇指作为支点,将显示屏再打开一点。
    • 现在不要试图完全分离显示屏。 Force Touch垫圈可能会粘在显示器或机身上,如果用力过猛,可能会被撕裂。
  4. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 4 中的图像 1,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 4 中的图像 2,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 4 中的图像 3,3
    • 在显示屏下方插入一个开口拨片,小心地将Force Touch垫圈与显示屏分开。
    • 确保您找对了位置。 如果在抬起显示屏时把Force Touch垫片分离了,或者您将垫圈层分开,则还需要更换Force Touch垫圈本身。
    • 在显示屏周围滑动拨片以分离Force Touch垫圈和显示屏之间的粘合剂。
    • 不要将开口拨片插入深度超过1/16英寸(~2 mm)。
  5. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 5 中的图像 1,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 5 中的图像 2,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 5 中的图像 3,3
    • 为避免损坏显示屏电缆,请勿完全打开显示屏。
    • 将显示屏打开约45°角,然后用镊子剥去显示屏和Force Touch垫圈之间的粘合剂。
    • 将粘合剂穿过显示器电缆的周围和后面,使其完全脱落,然后向下按压垫圈以重新粘附到盒子上。
    • 如果Force Touch垫圈本身松动且不会向下弯曲,则应更换垫圈下方和垫圈与显示屏之间的粘合剂。
  6. Apple Watch Series 2 Force Touch 垫圈更换, 断开电池: 步骤 6 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换, 断开电池: 步骤 6 中的图像 2,2
    • 卸下固定电池连接器的金属罩子的螺丝钉。
    • 用镊子取下罩子。
  7. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 7 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 7 中的图像 2,2
    • 用撬棒一角竖直向上撬动电池连接器断开电池。
    • 轻轻地让连接器向上弯,以防意外接触。
  8. Apple Watch Series 2 Force Touch 垫圈更换, Force Touch 垫圈: 步骤 8 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换, Force Touch 垫圈: 步骤 8 中的图像 2,2
    • 使用撬棒的尖端通过从外边缘直接向上撬动力触摸垫圈来断开它。
    • 你拔下的接口实际上通向主板。该接口下方的插座位于 Force Touch 垫圈本身上。
  9. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 9 中的图像 1,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 9 中的图像 2,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 9 中的图像 3,3
    • 抬起Force Touch 垫圈的接口板。
    • 将撬棒的尖端推到垫圈下方以分离下面的胶水。
    • 除了显示器电缆所在的边缘外,将胶水分别围绕手表的周边分开,以避免意外撕裂。
  10. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 10 中的图像 1,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 10 中的图像 2,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 10 中的图像 3,3
    • 小心地将Force Touch垫圈拉到显示屏上方和周围。
    • 翻转显示器几乎关闭,以便你可以安全地从剩余边缘剥离Force Touch垫圈。
    • 取下Force Touch垫圈。
  11. Apple Watch Series 2 Force Touch 垫圈更换, 清洁外壳: 步骤 11 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换, 清洁外壳: 步骤 11 中的图像 2,2
    • 在棉签上涂抹一点异丙醇(> 90%酒精)或使用清洁垫轻轻去除Force Touch垫圈上残留的任何粘合剂。
    • 要取下显示屏电缆下方的粘合剂,请将显示屏几乎关闭,并在清洁时轻轻将其拉离边缘。
  12. Apple Watch Series 2 Force Touch 垫圈更换, 清洁显示屏: 步骤 12 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换, 清洁显示屏: 步骤 12 中的图像 2,2
    • 翻转手表,使显示屏平放,同时略微抬起外壳。
    • 小心地从显示器背面取下任何残留的粘合剂。
  13. Apple Watch Series 2 Force Touch 垫圈更换, 安装新的垫圈: 步骤 13 中的图像 1,1
    • 使用一把镊子小心地从新的Force Touch垫圈底部取下保护膜。
    There’s a clear plastic stiffener that must be removed at the same time as or just before removing the protective liner. Be careful to remove only the plastic and not the protective liners, it is possible!
    Kyle Powderly - 回复
  14. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 14 中的图像 1,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 14 中的图像 2,3 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 14 中的图像 3,3
    • 沿对角方向握住 Force Touch 垫圈,将其穿过显示屏。
    • 稍微向前倾斜显示屏,以便将Force Touch垫圈与框架对齐。
    • 从 Force Touch 垫圈连接器对面的角落开始,将垫圈放在框架上,然后向下按压。
  15. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 15 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 15 中的图像 2,2
    • 使用撬棒将 Force Touch 垫圈的连接器板向下折叠到其凹槽中。
    • 通过撬棒轻轻按下柔性电缆重新连接。
  16. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 16 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 16 中的图像 2,2
    • 使用撬棒的尖端将电池连接器弯曲回原位。
    • 轻轻按下以重新连接电池柔性电缆。按下以重新连接电池柔性电缆。
  17. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 17 中的图像 1,2 Apple Watch Series 2 Force Touch 垫圈更换: 步骤 17 中的图像 2,2
    • 使用镊子将覆盖电池接口的金属板放回原位。
    • 安装Y型#000螺丝。
    • 此时,你可能需要打开手表并检查一切是否正常,然后再将其关闭。
    My watch didn’t turn until I connected it to a charger…
    Björn Tirsén - 回复
  18. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 18 中的图像 1,1
    • 使用一把镊子轻轻取下 Force Touch 垫圈顶部的保护膜。
  19. Apple Watch Series 2 Force Touch 垫圈更换: 步骤 19 中的图像 1,1
    • 对齐显示屏并将其牢牢按在粘合剂上。
    • 为了进一步改善粘合剂的粘合程度,你可以使用iOpener预热显示器,然后再将其按下约一分钟。
终点
48等其他人完成本指南。
由衷感谢以下译者:
en zh
57%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
7条评论
Hola, Me presento como nuevo y NOVATO. Me llamo Jaime, y Yo creo que os mereceis un 10. La caña de España.
Jaime Villa - 回复
Hola Jaime! Bienvenido! Muchas gracias por tu comentario. Nos alegra que te guste nuestro sitio. Cualquier duda que tengas, no dudes en consultarme. Soy la moderadora y líder de la comunidad hispanohablante.
Mariana Roca -
The gasket comes with all the necessary adhesive or you need to put he the sealing adhesive separately? I need to replace my screen and I got the gasket and screen but don’t know if I need glue to waterproof it?
Jose F - 回复
I bought iFixit’s battery replacement kit and the gasket which I received had adhesive on both sides, just like in this guide.
The repair kit does comes with extra gasket adhesive, which confused me at first. The extra adhesive is included in case you manage to open the watch without damaging the original gasket.
dalexgray -
I have no idea why they include the extra adhesives. When I tried to use one the screen sat too high and it looked bad.
Donald Fournier -
Thank you for an awesome guide. It got a little dodgy for a second there, but I replaced the screen, Force Touch Gasket and Battery. It works as new!
Donald Fournier - 回复
Congrats, welcome to the club of fixers :)
Tobias Isakeit -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 31
过去 30 天: 166
总计 25,740
