跳转到主内容
Apple Watch SE 1st Gen GPS NFC Replacement
你所需要的
  1. Apple Watch SE 1st Gen GPS NFC Replacement, Power down your watch: 步骤 1 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement, Power down your watch: 步骤 1 中的图像 2,2
  2. Apple Watch SE 1st Gen GPS NFC Replacement, Safety requirements: 步骤 2 中的图像 1,3 Apple Watch SE 1st Gen GPS NFC Replacement, Safety requirements: 步骤 2 中的图像 2,3 Apple Watch SE 1st Gen GPS NFC Replacement, Safety requirements: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch SE 1st Gen GPS NFC Replacement, Soften the display adhesive: 步骤 3 中的图像 1,1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  4. Apple Watch SE 1st Gen GPS NFC Replacement, Display opening: 步骤 4 中的图像 1,3 Apple Watch SE 1st Gen GPS NFC Replacement, Display opening: 步骤 4 中的图像 2,3 Apple Watch SE 1st Gen GPS NFC Replacement, Display opening: 步骤 4 中的图像 3,3
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
  5. Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 5 中的图像 1,3 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 5 中的图像 2,3 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 5 中的图像 3,3
    • Insert an opening pick in the gap you've created.
    • Slide the opening pick along the short edge of the watch to cut the adhesive.
  6. Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 6 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 6 中的图像 2,2
    • When slicing near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
    • Slide the opening pick around the corner and along the long edge where the crown is located to cut the display adhesive.
  7. Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 7 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 7 中的图像 2,2
    • Slide the opening pick around the corner to cut the remaining adhesive on the short edge farthest away from the crown.
  8. Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 8 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 8 中的图像 2,2
    • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
    • Slide an opening pick under the opposite display edge of the watch crown.
  9. Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 9 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 9 中的图像 2,2
    • Reinsert the opening pick on the short edge of the watch, next to the watch crown.
    • Twist the opening pick to loosen the display off the watch case.
    • Don't try to remove the display. It is still connected to the watch assembly.
  10. Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 10 中的图像 1,3 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 10 中的图像 2,3 Apple Watch SE 1st Gen GPS NFC Replacement: 步骤 10 中的图像 3,3
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it in direction of the short edge farthest away from the crown.
    • Swing the display open to an upward position.
  11. Apple Watch SE 1st Gen GPS NFC Replacement, Remove Apple Watch Screen: 步骤 11 中的图像 1,1
    • Carefully remove watch screen from current device
    • Don't rush and take your time
    • Disconnect 3 ribbon cables connected to screen
  12. Apple Watch SE 1st Gen GPS NFC Replacement, Remove NFC chip: 步骤 12 中的图像 1,3 Apple Watch SE 1st Gen GPS NFC Replacement, Remove NFC chip: 步骤 12 中的图像 2,3 Apple Watch SE 1st Gen GPS NFC Replacement, Remove NFC chip: 步骤 12 中的图像 3,3
    • Use a heatgun to heat up chip as it is attached with adhesive.
    • Use a Jimmy or razor blade to slowly lift chip
    • Chip is held by adhesive and two tiny soldered points
    • *Do not add too much heat as you might damage the screen. You just want enough to loosen adhesive.*
    • Remove NFC chip from the new screen you will be using. This is where you will reinstall the NFC from your previous screen.
  13. Apple Watch SE 1st Gen GPS NFC Replacement, Reinstall current NFC chip: 步骤 14 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement, Reinstall current NFC chip: 步骤 14 中的图像 2,2
    • Get the NFC chip from your old screen and solder two 0.02mm jumper cables on each solder connection to its corresponding point.
    • You do not need a lot of solder. Just enough to ensure a secure connection.
  14. Apple Watch SE 1st Gen GPS NFC Replacement, Check Device: 步骤 15 中的图像 1,3 Apple Watch SE 1st Gen GPS NFC Replacement, Check Device: 步骤 15 中的图像 2,3 Apple Watch SE 1st Gen GPS NFC Replacement, Check Device: 步骤 15 中的图像 3,3
    • Reconnect ribbon cables from watch back to the screen and turn on your device.
    • Test watch by using Apple Pay funciton
    • **The watch I used was factory reset. If Apple Pay doesn't function try resetting your device and ensure solder connections are secure.**
  15. Apple Watch SE 1st Gen GPS NFC Replacement, Secure NFC chip: 步骤 16 中的图像 1,2 Apple Watch SE 1st Gen GPS NFC Replacement, Secure NFC chip: 步骤 16 中的图像 2,2
    • Once you have ensured Apple Pay is functional, add a slight amount of green soldering resin on solder connections to ensure they are secure and don't make contact with other wire.
    • Add some T-7000 adhesive to the area labeled, "light amount" which is where the old adhesive was and glue it back to Apple Watch Screen and wait until the adhesive has dried and the NFC chip stays in place.
  16. Apple Watch SE 1st Gen GPS NFC Replacement, Reinstall Screen: 步骤 17 中的图像 1,1
    • Now that the NFC chip is secured, add T-7000 adhesive to the edges of the watch and reinstall the screen.
结论
Swapping the NFC wasn't easy. However, I have little to no knowledge in soldering and very little in electronic repair. However, after research and many trial and errors I finally managed to make it work and if me being someone who doesn't have much knowledge can do it then so can you :)
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 37
过去 30 天: 146
总计 1,705
