跳转到主内容
加入维修社区 - 创建账户
Apple Time Capsule Model A1254 Fan Replacement
你所需要的
    1. Apple Time Capsule Model A1254 Fan Replacement, Back Plate: 步骤 1 中的图像 1,3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: 步骤 1 中的图像 2,3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: 步骤 1 中的图像 3,3
      • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
      • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
      • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
      • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
      添加评论
    2. Apple Time Capsule Model A1254 Fan Replacement: 步骤 2 中的图像 1,2 Apple Time Capsule Model A1254 Fan Replacement: 步骤 2 中的图像 2,2
      • Remove the ten 3mm screws with a Phillips #00 screwdriver.
      • The screws with adhesive covering do not need to be removed.
      添加评论
    3. Apple Time Capsule Model A1254 Fan Replacement: 步骤 3 中的图像 1,2 Apple Time Capsule Model A1254 Fan Replacement: 步骤 3 中的图像 2,2
      • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
      • Pull the base of the wire close to the logic board and the connector will pop off.
      添加评论
    1. Apple Time Capsule Model A1254 Fan Replacement, Fan: 步骤 4 中的图像 1,2 Apple Time Capsule Model A1254 Fan Replacement, Fan: 步骤 4 中的图像 2,2
      • Orientate the back plate so that the fan is facing away from you.
      • Use the #0 Phillips Screw Drive to push the rubber shock mounts through the back plate.
      • Make sure that the head of the screw driver is centered on the head of the rubber shock mount so that it doesn't slip off causing possible injury.
      • When attaching the new fan, push the new rubber shock mounts through the back plate first. Attach the fan once all mounts are inserted.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
JR Alfano
于10/06/16注册
543 声望
撰写一个指南
团队
Cal Poly, Team 4-2, Livingston Fall 2016 Cal Poly, Team 4-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G2
4 名成员
创作了22篇指南
2指南评论
Hi where can I find the new rubber shock mount replacement for A-1254 fan replacement? thx.
V Q - 回复 分享
How do I get the rubber feet off the old fan and put them on the new fan?
Jim Matthews - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 40
总计 5,372
