跳转到主内容
加入维修社区 - 创建账户
Apple TV 4K Power Connector Replacement
你所需要的
    1. Apple TV 4K Power Connector Replacement, Logic Board: 步骤 1 中的图像 1,1
      • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
      • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
      添加评论
    2. Apple TV 4K Power Connector Replacement: 步骤 2 中的图像 1,2 Apple TV 4K Power Connector Replacement: 步骤 2 中的图像 2,2
      • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
      • Four 10 mm screws
      • Lift and remove the heat sink assembly from the device.
      添加评论
    3. Apple TV 4K Power Connector Replacement: 步骤 3 中的图像 1,2 Apple TV 4K Power Connector Replacement: 步骤 3 中的图像 2,2
      • Use plastic spudger to pull up on all three antenna connectors to remove them.
      • Remove rubber piece from front side of device.
      询问修复机器人
      添加评论
    4. Apple TV 4K Power Connector Replacement: 步骤 4 中的图像 1,1
      • Unscrew the following screws holding the logic board in place using the T7 Torx:
      • Two black 3 mm screws
      • Two silver 4 mm screws
      询问修复机器人
      添加评论
    5. Apple TV 4K Power Connector Replacement: 步骤 5 中的图像 1,3 Apple TV 4K Power Connector Replacement: 步骤 5 中的图像 2,3 Apple TV 4K Power Connector Replacement: 步骤 5 中的图像 3,3
      • Use a spudger to pry up logic board. Try lifting it up from the front side.
      • Remove logic board and set aside.
      询问修复机器人
      添加评论
    1. Apple TV 4K Power Connector Replacement, Power Connector: 步骤 6 中的图像 1,3 Apple TV 4K Power Connector Replacement, Power Connector: 步骤 6 中的图像 2,3 Apple TV 4K Power Connector Replacement, Power Connector: 步骤 6 中的图像 3,3
      • Use a T7 Torx to remove the screws:
      • Five 5mm screws
      • Carefully flip the device upside down to remove the logic board/power supply mount.
      询问修复机器人
      添加评论
    2. Apple TV 4K Power Connector Replacement: 步骤 7 中的图像 1,3 Apple TV 4K Power Connector Replacement: 步骤 7 中的图像 2,3 Apple TV 4K Power Connector Replacement: 步骤 7 中的图像 3,3
      • Disconnect the latch connecting the power connector to the power supply.
      • Feed the wire though the logic board/power supply mount. After this, remove the power connector from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G3
4 名成员
创作了25篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 82
总计 4,469
