跳转到主内容
加入维修社区 - 创建账户
Apple Studio Display M7649 Inverter Replacement
你所需要的
    1. Apple Studio Display M7649 Inverter Replacement, Stand: 步骤 1 中的图像 1,2 Apple Studio Display M7649 Inverter Replacement, Stand: 步骤 1 中的图像 2,2
      • Lay the display facing down with the stand away from you.
      • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
      询问修复机器人
      添加评论
    1. Apple Studio Display M7649 Inverter Replacement, Panels: 步骤 2 中的图像 1,1
      • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
      询问修复机器人
      添加评论
    2. Apple Studio Display M7649 Inverter Replacement: 步骤 3 中的图像 1,1
      • Rotate the display so the legs of the display are now facing you
      • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
      询问修复机器人
      添加评论
    3. Apple Studio Display M7649 Inverter Replacement: 步骤 4 中的图像 1,1
      • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
      询问修复机器人
      添加评论
    1. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: 步骤 5 中的图像 1,1
      • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
      询问修复机器人
      添加评论
    2. Apple Studio Display M7649 Inverter Replacement: 步骤 6 中的图像 1,1
      • Now locate and remove the lone Phillips screw holding the EMI shield to the display
      询问修复机器人
      添加评论
    3. Apple Studio Display M7649 Inverter Replacement: 步骤 7 中的图像 1,2 Apple Studio Display M7649 Inverter Replacement: 步骤 7 中的图像 2,2
      • Now that the screw has been removed, slide the panel towards your body and lift it out.
      • You may need to remove the clear USB port cover to remove the metal EMI shield.
      询问修复机器人
      添加评论
    1. Apple Studio Display M7649 Inverter Replacement, Inverter: 步骤 8 中的图像 1,1
      • Remove these three screws holding the board to the display
      询问修复机器人
      添加评论
    2. Apple Studio Display M7649 Inverter Replacement: 步骤 9 中的图像 1,1
      • Remove these five cables connection the inverter to the backlights and logic board.
      • Taking note where they connect to for reassembly
      询问修复机器人
      添加评论
    3. Apple Studio Display M7649 Inverter Replacement: 步骤 10 中的图像 1,1
      • Remove and replace the inverter
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Andrew Tsao
于01/19/10注册
186 声望
创作了5篇指南
团队
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G20
4 名成员
创作了31篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 38
总计 7,873
