跳转到主内容
加入维修社区 - 创建账户
Apple Powerbook 5300 Memory Replacement
你所需要的
  1. Apple Powerbook 5300 Memory Replacement, Battery: 步骤 1 中的图像 1,2 Apple Powerbook 5300 Memory Replacement, Battery: 步骤 1 中的图像 2,2
    • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
    • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
    询问修复机器人
    添加评论
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: 步骤 2 中的图像 1,1
    • For the next step you are to grab the TR8 Torx Security Screwdriver
    • Once you have the screwdriver turn the laptop over and look for three T8 torx screws that should be located near the bottom panel of the device.
    • Once located, begin unscrewing and place screws in a comfortable space where they are easily accesible
    询问修复机器人
    添加评论
  3. Apple Powerbook 5300 Memory Replacement: 步骤 3 中的图像 1,1
    • Once the screws are off carefully turn the laptop over, make sure the monitor of the device is facing you
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use the spudger tool to lift the white plastic retainer about 1/16" to release the cable.
    添加评论
  4. Apple Powerbook 5300 Memory Replacement, Memory: 步骤 4 中的图像 1,1
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Scott
于04/26/11注册
155 声望
创作了5篇指南
团队
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G30
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 39
总计 2,880
