本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will take you through the steps necessary to disassemble your Powerbook 5300, reach its hard drive, and replace it.
你所需要的
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
2等其他人完成本指南。
