跳转到主内容
加入维修社区 - 创建账户
Apple PowerBook G3 400 Keyboard Replacement
  1. Apple PowerBook G3 400 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
    询问修复机器人
    添加评论
  2. Apple PowerBook G3 400 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
    添加评论
  3. Apple PowerBook G3 400 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Your computer should look approximately like this.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Byron Hoefer
于04/18/11注册
70 声望
创作了2篇指南
团队
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011 的会员
CPSU-REGAN-S11S4G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 26
总计 2,181
