跳转到主内容
加入维修社区 - 创建账户
Apple Magic Keyboard Keys Repair
你所需要的
      • Remove the batteries.
      • Remove the plastic cover on the bottom. (On older models, this cover is not centered.)
      • Remove the small screw.
      询问修复机器人
      添加评论
      • Use a flat blunt tool to loosen the ribbon cable clamp. To do this, pull the front part away from the rear part.
      • Pull out the ribbon cable.
      询问修复机器人
      添加评论
      • Put the batteries back in (without screwing the cover on).
      • Push in the batteries to release the circuit board assembly.
      • Carefully pull out the circuit board assembly. Pay attention to the ribbon cable.
      添加评论
      • Soak the keyboard in alcohol (methylated spirits). It should be completely covered. Use an airtight container.
      • Keep moving the container to get the liquid everywhere.
      • Wait 24 hours
      询问修复机器人
      添加评论
      • Take the keyboard out of the liquid and shake it out well.
      • CAUTION!! This step is not absolutely necessary!! Opening the keyboard further is only necessary if you want to gain access to the circuit paths.
      • The plastic cover on the back can now be easily detached. To do this, use a flat blunt tool to go into the gap and pry off the plastic cover. The alcohol has softened the glue.
      • Let the keyboard dry well. To speed up the process, you can put it into the sun.
      询问修复机器人
      添加评论
      • Put the parts back together in reverse order. When installing the circuit board unit, make sure that you pull the ribbon cable to the side.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 39
过去 30 天: 195
总计 6,434
