跳转到主内容
加入维修社区 - 创建账户
Apple IIc Speaker Replacement
你所需要的
  1. Apple IIc Speaker Replacement, Disassembling Apple IIc Cover: 步骤 1 中的图像 1,2 Apple IIc Speaker Replacement, Disassembling Apple IIc Cover: 步骤 1 中的图像 2,2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    询问修复机器人
    添加评论
  2. Apple IIc Speaker Replacement: 步骤 2 中的图像 1,2 Apple IIc Speaker Replacement: 步骤 2 中的图像 2,2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    询问修复机器人
    添加评论
  3. Apple IIc Speaker Replacement: 步骤 3 中的图像 1,2 Apple IIc Speaker Replacement: 步骤 3 中的图像 2,2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    添加评论
  4. Apple IIc Speaker Replacement: 步骤 4 中的图像 1,2 Apple IIc Speaker Replacement: 步骤 4 中的图像 2,2
    • Lift the handle straight up to remove.
    询问修复机器人
    添加评论
  5. Apple IIc Speaker Replacement, Keyboard: 步骤 5 中的图像 1,2 Apple IIc Speaker Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    询问修复机器人
    添加评论
  6. Apple IIc Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
    • Unplug the speaker from the mother board by pulling horizontally.
    询问修复机器人
    添加评论
  7. Apple IIc Speaker Replacement: 步骤 7 中的图像 1,1
    • Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
    • An easy way to heat the glue is by using a hair dryer on a low setting.
    • When heating the glue, do not use any high wattage device! This may burn or damage the chips or circuit board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Josiah
于10/06/11注册
658 声望
创作了3篇指南
团队
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G23
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 2,016
