跳转到主内容
加入维修社区 - 创建账户
Apex Tablet 7 Camera Replacement
你所需要的
    1. Apex Tablet 7 Camera Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      添加评论
    2. Apex Tablet 7 Camera Replacement: 步骤 2 中的图像 1,2 Apex Tablet 7 Camera Replacement: 步骤 2 中的图像 2,2
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      询问修复机器人
      添加评论
    3. Apex Tablet 7 Camera Replacement: 步骤 3 中的图像 1,2 Apex Tablet 7 Camera Replacement: 步骤 3 中的图像 2,2
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      询问修复机器人
      添加评论
    4. Apex Tablet 7 Camera Replacement: 步骤 4 中的图像 1,1
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      询问修复机器人
      添加评论
    5. Apex Tablet 7 Camera Replacement: 步骤 5 中的图像 1,1
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      询问修复机器人
      添加评论
    1. Apex Tablet 7 Camera Replacement, Camera: 步骤 6 中的图像 1,2 Apex Tablet 7 Camera Replacement, Camera: 步骤 6 中的图像 2,2
      • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
      询问修复机器人
      添加评论
    2. Apex Tablet 7 Camera Replacement: 步骤 7 中的图像 1,1
      • Flip the black latch over the gold cable to the upright position in order to release the cable.
      询问修复机器人
      添加评论
    3. Apex Tablet 7 Camera Replacement: 步骤 8 中的图像 1,1
      • Carefully remove the cable from the circuit by pulling it straight out.
      询问修复机器人
      添加评论
    4. Apex Tablet 7 Camera Replacement: 步骤 9 中的图像 1,1
      • Pull out the camera. There should not be any more connections holding it in place.
      • Reconnect the replacement camera.
      询问修复机器人
      添加评论
结论
To place the new part and reassemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team 2-2, Grigsby Spring 2015 Baylor, Team 2-2, Grigsby Spring 2015 的会员
BU-GRIGSBY-S15S2G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 722
