跳转到主内容
加入维修社区 - 创建账户
Anker Soundcore Space One Ear Pad Replacement
你所需要的
    1. Anker Soundcore Space One Ear Pad Replacement, Ear Pads: 步骤 1 中的图像 1,1
      • Flip over the device so the ear pads face up.
      • This replacement guide will only cover one of the ear pads. The same exact steps apply to both.
      询问修复机器人
      添加评论
    2. Anker Soundcore Space One Ear Pad Replacement: 步骤 2 中的图像 1,2 Anker Soundcore Space One Ear Pad Replacement: 步骤 2 中的图像 2,2
      • Insert a spudger (plastic or metal) between the ear pad and the driver housing (the driver housing is the outside plastic part of ear cup).
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one.
      • Pry around the ear pad in a circular path until it fully releases.
      询问修复机器人
      添加评论
    3. Anker Soundcore Space One Ear Pad Replacement: 步骤 3 中的图像 1,1
      • Remove the ear pad from the driver housing.
      • The gray foam component shown is an additional protective component of the ear pad. You can remove it with your hands if needed, without any tools.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Malcolm Hewlett
于03/21/25注册
433 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G3
3 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 85
过去 30 天: 298
总计 1,954
