跳转到主内容
加入维修社区 - 创建账户
Android tablet Digitiser Replacement
      • I have no sophisticated device to unglue the bezel. What I did is use a small kitchen oven. The top of the oven becomes hot when I’m using it. I set it to 6 (180C), then I placed the digitiser assembly face down on the top of the oven (not inside!). After 5 minutes, I inserted a kitchen knife between digitiser and bezel and separated them.
      询问修复机器人
      添加评论
      • In order to clean the bezel, I recommend to use alcohol. I tried with nail polish remover and it is too strong, it damages the bezel. Alcohol is less aggressive and it will take a little more mechanical effort, yet I could do it.
      询问修复机器人
      添加评论
      • After I cleaned the bezel, I removed the protective film off the inner side of the digitiser. I removed the protecting straps of the double sided tape, then carefully pulled the flat cable through the hole and glued the digitiser with the bezel to form the digitiser assembly.
      询问修复机器人
      添加评论
      • The digitiser shouldn’ Be stained as you just removed the protecting film. The screen might well be dirty. Remember it is highly sensitive to touch. Therefore, I used a dry cloth to softly brush off the small glass pieces. Don’t overdo, just brush them off without exercising any pressure.
      询问修复机器人
      添加评论
      • Just redo the steps you needed to disassemble the tablet in reverse order...
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
bclabots
于12/15/13注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 609
