跳转到主内容
加入维修社区 - 创建账户
Amazon Luna Controller Shell Replacement
你所需要的
  1. Amazon Luna Controller Shell Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the controller over so that the back panel is facing up.
    询问修复机器人
    添加评论
  2. Amazon Luna Controller Shell Replacement: 步骤 2 中的图像 1,3 Amazon Luna Controller Shell Replacement: 步骤 2 中的图像 2,3 Amazon Luna Controller Shell Replacement: 步骤 2 中的图像 3,3
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
    询问修复机器人
    添加评论
  3. Amazon Luna Controller Shell Replacement, Faceplate: 步骤 3 中的图像 1,1
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
    询问修复机器人
    添加评论
  4. Amazon Luna Controller Shell Replacement: 步骤 4 中的图像 1,1
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
    询问修复机器人
    添加评论
  5. Amazon Luna Controller Shell Replacement: 步骤 5 中的图像 1,2 Amazon Luna Controller Shell Replacement: 步骤 5 中的图像 2,2
    • Once all clips are released, lift the front plate away from the controller.
    询问修复机器人
    添加评论
  6. Amazon Luna Controller Shell Replacement, Buttons: 步骤 6 中的图像 1,2 Amazon Luna Controller Shell Replacement, Buttons: 步骤 6 中的图像 2,2
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
    询问修复机器人
    添加评论
  7. Amazon Luna Controller Shell Replacement: 步骤 7 中的图像 1,2 Amazon Luna Controller Shell Replacement: 步骤 7 中的图像 2,2
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
    询问修复机器人
    添加评论
  8. Amazon Luna Controller Shell Replacement: 步骤 8 中的图像 1,3 Amazon Luna Controller Shell Replacement: 步骤 8 中的图像 2,3 Amazon Luna Controller Shell Replacement: 步骤 8 中的图像 3,3
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
    询问修复机器人
    添加评论
  9. Amazon Luna Controller Shell Replacement, Joystick Cover: 步骤 9 中的图像 1,2 Amazon Luna Controller Shell Replacement, Joystick Cover: 步骤 9 中的图像 2,2
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
    询问修复机器人
    添加评论
  10. Amazon Luna Controller Shell Replacement, Shell: 步骤 10 中的图像 1,2 Amazon Luna Controller Shell Replacement, Shell: 步骤 10 中的图像 2,2
    • Gently grab the controller's circuitry and hold the bottom shell.
    • Pull the circuitry gently out from the shell.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
2指南评论
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - 回复 分享
I would check your reassembly and make sure none of the pads are damaged under the buttons
Ethan Phillips - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 365
