跳转到主内容
加入维修社区 - 创建账户
Amazon Fire TV Cube Button Replacement
你所需要的
    1. Amazon Fire TV Cube Button  Replacement, Speaker: 步骤 1 中的图像 1,3 Amazon Fire TV Cube Button  Replacement, Speaker: 步骤 1 中的图像 2,3 Amazon Fire TV Cube Button  Replacement, Speaker: 步骤 1 中的图像 3,3
      • Using a metal spudger, push down between the edge seals on the base and pry off the base.
      • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
      • This may require substantial force.
      询问修复机器人
      添加评论
    2. Amazon Fire TV Cube Button  Replacement: 步骤 2 中的图像 1,3 Amazon Fire TV Cube Button  Replacement: 步骤 2 中的图像 2,3 Amazon Fire TV Cube Button  Replacement: 步骤 2 中的图像 3,3
      • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
      • There are 4 washers to go with each of the screws.
      询问修复机器人
      添加评论
    3. Amazon Fire TV Cube Button  Replacement: 步骤 3 中的图像 1,1
      • Lift and remove the full frame.
      询问修复机器人
      添加评论
    4. Amazon Fire TV Cube Button  Replacement: 步骤 4 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 4 中的图像 2,2
      • Lift and remove the speaker.
      • Carefully match the outlets on the speaker with the outlets on the motherboard.
      询问修复机器人
      添加评论
    1. Amazon Fire TV Cube Button  Replacement, Motherboard: 步骤 5 中的图像 1,2 Amazon Fire TV Cube Button  Replacement, Motherboard: 步骤 5 中的图像 2,2
      • Lift the black latch by gently prying up with the flat end of the Spudger.
      • Detach the copper tap by pulling it out.
      询问修复机器人
      添加评论
    2. Amazon Fire TV Cube Button  Replacement: 步骤 6 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 6 中的图像 2,2
      • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
      • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
      询问修复机器人
      添加评论
    3. Amazon Fire TV Cube Button  Replacement: 步骤 7 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 7 中的图像 2,2
      • Gently pry the motherboard up and off.
      添加评论
    1. Amazon Fire TV Cube Button  Replacement, Button: 步骤 8 中的图像 1,3 Amazon Fire TV Cube Button  Replacement, Button: 步骤 8 中的图像 2,3 Amazon Fire TV Cube Button  Replacement, Button: 步骤 8 中的图像 3,3
      • Detach the wires from the opposite end of the frame using the flat end of the Spudger.
      • You can’t see where the wires are attached because it is hidden underneath the white frame.
      • Make sure both wire attachments are fully disconnected before continuing.
      询问修复机器人
      添加评论
    2. Amazon Fire TV Cube Button  Replacement: 步骤 9 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 9 中的图像 2,2
      • Pry apart the black plastic face from metal frame.
      • This requires substantial force.
      • Be careful not to tear connecting copper tab.
      询问修复机器人
      添加评论
    3. Amazon Fire TV Cube Button  Replacement: 步骤 10 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 10 中的图像 2,2
      在这个步骤中使用的工具:
      $3.99
      • Lift the black latch to detach the copper tab by gently prying with the angled Tweezers.
      • Use the Angled Tweezers to carefully pull out the copper tab.
      询问修复机器人
      添加评论
    4. Amazon Fire TV Cube Button  Replacement: 步骤 11 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 11 中的图像 2,2
      • Unscrew the five T-6 quarter inch screws.
      询问修复机器人
      添加评论
    5. Amazon Fire TV Cube Button  Replacement: 步骤 12 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 12 中的图像 2,2
      • Lift and remove white the frame to reveal the circuit board.
      询问修复机器人
      添加评论
    6. Amazon Fire TV Cube Button  Replacement: 步骤 13 中的图像 1,3 Amazon Fire TV Cube Button  Replacement: 步骤 13 中的图像 2,3 Amazon Fire TV Cube Button  Replacement: 步骤 13 中的图像 3,3
      • Using a the Metal Spudger, pry up the circuit board to reveal a rubber button panel.
      询问修复机器人
      添加评论
    7. Amazon Fire TV Cube Button  Replacement: 步骤 14 中的图像 1,2 Amazon Fire TV Cube Button  Replacement: 步骤 14 中的图像 2,2
      • Peel back the rubber button casing.
      • Pay close attention to the orientation of the rubber casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
1指南评论
A suggestion for step 8: the antenna wires are not soldered to the aluminum heatsink; they are soldered to small clips that are easily popped off from the heatsink. I found it much easier to pop off all the clips and free the antenna wires from the heatsink than try to remove the antenna connectors from the top circuit board while it is still attached to the frame. After removing the top circuit board from the frame, it’s then much easier to remove the antenna connectors.
Phil G - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 3,410
