跳转到主内容
加入维修社区 - 创建账户
Amazon Fire Phone Battery Replacement
你所需要的
  1. Amazon Fire Phone Battery Replacement, Tape the screen: 步骤 1 中的图像 1,1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
    询问修复机器人
    添加评论
  2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 1,3 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 2,3 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 3,3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
    询问修复机器人
    添加评论
  3. Amazon Fire Phone Battery Replacement: 步骤 3 中的图像 1,3 Amazon Fire Phone Battery Replacement: 步骤 3 中的图像 2,3 Amazon Fire Phone Battery Replacement: 步骤 3 中的图像 3,3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
    询问修复机器人
    添加评论
  4. Amazon Fire Phone Battery Replacement, Remove Bracket: 步骤 4 中的图像 1,1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    添加评论
  5. Amazon Fire Phone Battery Replacement, Disconnect Battery: 步骤 5 中的图像 1,1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    添加评论
结论
取消:我没有完成这个指南。
22等其他人完成本指南。
团队
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G7
5 名成员
创作了15篇指南
14指南评论
Tolle Anleitung DANKE!!
Leo Henn - 回复 分享
The replacement went exactly as presented. My stock battery had pull tabs to release the adhesive, making removal very easy. Thanks for a clear step-by-step guide.
John - 回复 分享
How to bay amazone fire fone battry in pakistan
Manzoor Khan - 回复 分享
where can i get fire phone battery in india
Shiva Sai - 回复 分享
where can i get fire phone battery in UAE Abu Dhabi. It's urgent..
Asheesh Barna - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 55
总计 14,416
