跳转到主内容
加入维修社区 - 创建账户
Amazon Fire HD 8 12th Gen Screen Replacement
你所需要的
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: 步骤 1 中的图像 1,3 Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: 步骤 1 中的图像 2,3 Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: 步骤 1 中的图像 3,3
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      询问修复机器人
      添加评论
    2. Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 2 中的图像 1,2 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 2 中的图像 2,2
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      询问修复机器人
      添加评论
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Battery: 步骤 3 中的图像 1,2 Amazon Fire HD 8 12th Gen Screen Replacement, Battery: 步骤 3 中的图像 2,2
      • Using the iFixit opening tool, disconnect the battery from the circuit board.
      询问修复机器人
      添加评论
    2. Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 4 中的图像 3,3
      • Slowly and gently, pull and remove the 3 adhesives under the old battery.
      • Remove all 3 by pulling the adhesive, signified by a black flap with white adhesive. You will know it is removed when the adhesive has come out from under the battery and you are now able to move the battery.
      添加评论
    3. Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 5 中的图像 1,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 5 中的图像 2,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 5 中的图像 3,3
      • Remove the old battery from the device using the opening tool.
      • If necessary, clean under your old battery and then insert the new battery with new adhesive to ensure the battery stays in place.
      询问修复机器人
      添加评论
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Screen: 步骤 6 中的图像 1,2 Amazon Fire HD 8 12th Gen Screen Replacement, Screen: 步骤 6 中的图像 2,2
      • Start off by heating the edges of the screen to melt the adhesive.
      • Insert the opening picks between the screen and device.
      询问修复机器人
      添加评论
    2. Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 7 中的图像 1,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 7 中的图像 2,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 7 中的图像 3,3
      • Slide the opening pick in between the screen and device, prying it just above the device.
      • Place the suction on the screen
      询问修复机器人
      添加评论
    3. Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 8 中的图像 1,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 8 中的图像 2,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 8 中的图像 3,3
      • Gently pull the screen off using the suction and opening tool.
      询问修复机器人
      添加评论
    4. Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 9 中的图像 1,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 9 中的图像 2,3 Amazon Fire HD 8 12th Gen Screen Replacement: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      • Heat up the little black square with yellow orange tape around it on the back of the device, atop the motherboard.
      • Once heated, remove the little black square using tweezers. Unhooking the screen from the screen.
      • Pulling the suction cup, fully remove the screen from the device.
      添加评论
结论
取消:我没有完成这个指南。
Rama Sura
于02/13/23注册
454 声望
创作了3篇指南
团队
1指南评论
Where can i buy a replacement screen?
Imfenway - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 186
总计 4,947
