跳转到主内容
加入维修社区 - 创建账户
Amazon Fire HD 8 12th Gen Button Replacement
你所需要的
    1. Amazon Fire HD 8 12th Gen Button Replacement, Buttons: 步骤 1 中的图像 1,3 Amazon Fire HD 8 12th Gen Button Replacement, Buttons: 步骤 1 中的图像 2,3 Amazon Fire HD 8 12th Gen Button Replacement, Buttons: 步骤 1 中的图像 3,3
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      询问修复机器人
      添加评论
    2. Amazon Fire HD 8 12th Gen Button Replacement: 步骤 2 中的图像 1,2 Amazon Fire HD 8 12th Gen Button Replacement: 步骤 2 中的图像 2,2
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jaden Palmer
于09/06/23注册
485 声望
创作了4篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 67
总计 661
