跳转到主内容
加入维修社区 - 创建账户
Amazon Fire 5th Generation Battery Replacement
你所需要的
    1. Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: 步骤 1 中的图像 1,2 Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: 步骤 1 中的图像 2,2
      • Ensure that your device is turned off.
      • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
      • Holding the Fire firmly, wedge a plastic opening tool into the crease on the edge of the device.
      • Slowly work the plastic opening tool around the device until the entire back cover releases from the front of the device.
      询问修复机器人
      添加评论
    2. Amazon Fire 5th Generation Battery Replacement: 步骤 2 中的图像 1,3 Amazon Fire 5th Generation Battery Replacement: 步骤 2 中的图像 2,3 Amazon Fire 5th Generation Battery Replacement: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      $3.99
      • Using angled ESD precision tweezers, lift up on the battery cables to separate the battery connector from its socket.
      • Be sure to lift the battery connector cables themselves and not the actual socket. Doing this step incorrectly could damage the connector.
      询问修复机器人
      添加评论
    3. Amazon Fire 5th Generation Battery Replacement: 步骤 3 中的图像 1,3 Amazon Fire 5th Generation Battery Replacement: 步骤 3 中的图像 2,3 Amazon Fire 5th Generation Battery Replacement: 步骤 3 中的图像 3,3
      • Carefully and slowly work a large plastic opening tool along the edge of the battery pack. Angle the tool to pry it up.
      • When you have successfully lifted the battery pack up on one side or corner, carefully wedge the opening tool under the pack about 1/2" and work around the rest of the sides.
      • Be careful not to bend the battery. Don't use too much force, as it can damage the battery.
      添加评论
结论
取消:我没有完成这个指南。
25等其他人完成本指南。
团队
USF Tampa, Team 1-2, Nance Spring 2016 USF Tampa, Team 1-2, Nance Spring 2016 的会员
USFT-NANCE-S16S1G2
3 名成员
创作了13篇指南
9指南评论
Where do you purchase the replacement battery (and what part number)?
John LaRue - 回复 分享
Battery to buy right below!
https://www.ebay.com/itm/2980mAh-Battery...
Jorge Hurtado - 回复 分享
Thanks for this guide Maximilian, and also for the link to purchase the battery, commenter Jorge! Those batteries seem to be pretty difficult to find online. Amazon definitely doesn’t make it easy to find them even on their own site, though they seem happy to sell a replacement fire… :)
crimsontideaggie - 回复 分享
Update: I had to do two of these, and it didn’t take me any longer than 10 minutes for either one of them. Easy peasy, thanks for the clear and concise guide.
If the battery connector comes off does it need soldering back on
Ashley Pollen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 51
过去 30 天: 224
总计 26,725
