跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Studio Subwoofer Replacement
你所需要的
    1. Amazon Echo Studio Subwoofer Replacement, Power Supply Board: 步骤 1 中的图像 1,3 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: 步骤 1 中的图像 2,3 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: 步骤 1 中的图像 3,3
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      添加评论
    2. Amazon Echo Studio Subwoofer Replacement: 步骤 2 中的图像 1,3 Amazon Echo Studio Subwoofer Replacement: 步骤 2 中的图像 2,3 Amazon Echo Studio Subwoofer Replacement: 步骤 2 中的图像 3,3
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      添加评论
    3. Amazon Echo Studio Subwoofer Replacement: 步骤 3 中的图像 1,3 Amazon Echo Studio Subwoofer Replacement: 步骤 3 中的图像 2,3 Amazon Echo Studio Subwoofer Replacement: 步骤 3 中的图像 3,3
      • Before fully removing the base, remove the three attached connectors.
      询问修复机器人
      添加评论
    4. Amazon Echo Studio Subwoofer Replacement: 步骤 4 中的图像 1,2 Amazon Echo Studio Subwoofer Replacement: 步骤 4 中的图像 2,2
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      添加评论
    1. Amazon Echo Studio Subwoofer Replacement, Subwoofer: 步骤 5 中的图像 1,1
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
      询问修复机器人
      添加评论
    2. Amazon Echo Studio Subwoofer Replacement: 步骤 6 中的图像 1,3 Amazon Echo Studio Subwoofer Replacement: 步骤 6 中的图像 2,3 Amazon Echo Studio Subwoofer Replacement: 步骤 6 中的图像 3,3
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
      添加评论
    3. Amazon Echo Studio Subwoofer Replacement: 步骤 7 中的图像 1,2 Amazon Echo Studio Subwoofer Replacement: 步骤 7 中的图像 2,2
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jaiden Wiles
于10/26/22注册
178 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G6
4 名成员
创作了13篇指南
1指南评论
Does anybody know where to get a replacement subwoofer?
Matthew Johnson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 49
总计 1,630
