跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Show Back Cover Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
    1. Amazon Echo Show Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Amazon Echo Show Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
      • Using your hands, gently remove the taped-in rubber foot from device.
      询问修复机器人
      添加评论
    2. Amazon Echo Show Back Cover Replacement: 步骤 2 中的图像 1,2 Amazon Echo Show Back Cover Replacement: 步骤 2 中的图像 2,2
      • Carefully peel off the bottom pad to expose the fastening screws.
      • Remove three silver 1.4 T5 Torx screws on the top row.
      • Remove one green 1mm T5 Torx screw in the middle.
      • Remove a black 1.5mm T5 screw.
      • Remove three green 1mm T5 screws from the bottom row.
      询问修复机器人
      添加评论
    3. Amazon Echo Show Back Cover Replacement: 步骤 3 中的图像 1,1
      • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
      询问修复机器人
      添加评论
    4. Amazon Echo Show Back Cover Replacement: 步骤 4 中的图像 1,2 Amazon Echo Show Back Cover Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
      • Repeat this step for the other speaker, and lay the front section flat with the facing down.
      • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2指南评论
this particular guide originally only had the prerequisite guide portion, so the steps to replace the top buttons were repeated across every single guide we had. I adjusted the prerequisite guide to include the separation of the two halves and moved the top button replacement guide to its own page. As this is still a private guide, it won’t be published unless we approve it.
Justin Williams - 回复 分享
This article has been flagged as the prerequisite guide for a few of our articles, so I ended up altering it to be such. However, the ones that are not linked to this one, I added a few steps.
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 642
