跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Show 5-Megapixel Camera Replacement
你所需要的
    1. Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: 步骤 1 中的图像 1,2 Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: 步骤 1 中的图像 2,2
      • Use the plastic opening tool to gently lift the plastic protector from the screen.
      询问修复机器人
      添加评论
    2. Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 2 中的图像 1,2 Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 2 中的图像 2,2
      • After the protector has been removed, use your hands to gently remove the taped-in rubber foot from device.
      询问修复机器人
      添加评论
    3. Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 3 中的图像 1,1
      • Carefully peel off the bottom pad to expose the fastening screws.
      • Remove three silver 1.4 T5 Torx screws on the top row.
      • Remove one green 1mm T5 Torx screw in the middle.
      • Remove a black 1.5mm T5 screw.
      • Remove three green 1mm T5 screws from the bottom row.
      询问修复机器人
      添加评论
    4. Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 4 中的图像 1,3 Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 4 中的图像 2,3 Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
      • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
      • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
      • Lay the front section flat, with the screen down.
      询问修复机器人
      添加评论
    5. Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 5 中的图像 1,3 Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 5 中的图像 2,3 Amazon Echo Show 5-Megapixel Camera  Replacement: 步骤 5 中的图像 3,3
      • Remove two 1mm T5 Torx screws.
      • Once the screws have been removed, you can easily remove the camera from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
1指南评论
Can not reset amazon echo show model MW46WB tried everything any suggestions
Skippy Gessler - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 2,552
