简介
Follow this guide to replace the Amazon Echo Show Display. The display is especially susceptible to damage because of its exposed nature.
你所需要的
Orient the Amazon Echo Show 5 so that the display is face down.
Use a spudger to remove the grey bottom cover.
Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
在这个步骤中使用的工具:Tweezers$4.99
Use the Philips #000 Screwdriver to remove two 4mm screws that hold down the metal bracket.
Use tweezers to remove the metal bracket by lifting it up and towards yourself.
Use tweezers to remove the camera from the display assembly.
Orient the Amazon Echo Show 5 so that the display is facing up.
Apply heat to the edges of the display using a heat gun.
5等其他人完成本指南。
3指南评论
Hey Zachary,
Great guide, thanks for the help. Now I'm on to figuring out if it's possible to zombify the screen and touchscreen using a raspberry pi. Wish me luck...
Thanks,
Graham
Does replacing the screen fix the glitching/flickering issue?
Messwithit - 回复 分享
