跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Show 15 Buttons Replacement
你所需要的
    1. Amazon Echo Show 15 Buttons Replacement, Back Panel: 步骤 1 中的图像 1,3 Amazon Echo Show 15 Buttons Replacement, Back Panel: 步骤 1 中的图像 2,3 Amazon Echo Show 15 Buttons Replacement, Back Panel: 步骤 1 中的图像 3,3
      • Remove the four white stickers on your device's back panel.
      • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
      • A hair dryer may work best for this step.
      询问修复机器人
      添加评论
    2. Amazon Echo Show 15 Buttons Replacement: 步骤 2 中的图像 1,3 Amazon Echo Show 15 Buttons Replacement: 步骤 2 中的图像 2,3 Amazon Echo Show 15 Buttons Replacement: 步骤 2 中的图像 3,3
      • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
      • Pop the sides and remove the back panel of the device.
      询问修复机器人
      添加评论
    1. Amazon Echo Show 15 Buttons Replacement, Inner Black Panel: 步骤 3 中的图像 1,3 Amazon Echo Show 15 Buttons Replacement, Inner Black Panel: 步骤 3 中的图像 2,3 Amazon Echo Show 15 Buttons Replacement, Inner Black Panel: 步骤 3 中的图像 3,3
      • In the top right corner you will find a small black panel.
      • Remove the five 2 mm screws with a Torx T5 screwdriver.
      • Remove the two 5 mm with a Torx T3 screwdriver.
      • Remove both ends of the connector from the main device.
      • Remove the black panel.
      添加评论
    1. Amazon Echo Show 15 Buttons Replacement, Motherboard: 步骤 4 中的图像 1,3 Amazon Echo Show 15 Buttons Replacement, Motherboard: 步骤 4 中的图像 2,3 Amazon Echo Show 15 Buttons Replacement, Motherboard: 步骤 4 中的图像 3,3
      • Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
      • Take off the metal protector.
      • The metal protector is connected to the motherboard with adhesive. More force may be necessary.
      • Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
      询问修复机器人
      添加评论
    2. Amazon Echo Show 15 Buttons Replacement: 步骤 5 中的图像 1,3 Amazon Echo Show 15 Buttons Replacement: 步骤 5 中的图像 2,3 Amazon Echo Show 15 Buttons Replacement: 步骤 5 中的图像 3,3
      • Detach the connectors for the camera and buttons from the motherboard.
      • Detach the connectors for the power station and speakers from the motherboard.
      • Detach the small white coaxial cables from the motherboard.
      • These connectors will be reused, so be very careful with them. The small white connectors come off by being pulled up.
      询问修复机器人
      添加评论
    3. Amazon Echo Show 15 Buttons Replacement: 步骤 6 中的图像 1,1
      • Remove the motherboard from the main device.
      询问修复机器人
      添加评论
    1. Amazon Echo Show 15 Buttons Replacement, Buttons: 步骤 7 中的图像 1,3 Amazon Echo Show 15 Buttons Replacement, Buttons: 步骤 7 中的图像 2,3 Amazon Echo Show 15 Buttons Replacement, Buttons: 步骤 7 中的图像 3,3
      • Remove the three 3 mm screws from the green panel in the top right-hand corner of the device using a Phillips #1 screwdriver.
      • Remove the green panel.
      • The green panel is connected to the main device with adhesive. You will need to use a bit more force to get it out.
      询问修复机器人
      添加评论
    2. Amazon Echo Show 15 Buttons Replacement: 步骤 8 中的图像 1,1
      • Remove the rubber part of the buttons.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 的会员
UTAHTECH-MCMURRIN-F23S1G4
3 名成员
创作了14篇指南
1指南评论
I bet this is what I need to do, I’ve cleaned motherboards with the rubber push pads on snow plow controls I’ve had my pickup. Like Red Bull, coffee, spills that snuck their way in( gross) but after cleaning and or letting things air out, back in biz.buying the driver kit tomorrow thank you very much for being so clever two yrs ago! And the heads up about adhesive thanks. I miss my Show 15
All my daughter’s pics and all that jazz, miss seeing it everyday. Thank You !!🌳
Treeman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 45
总计 642
