跳转到主内容
Amazon Echo Show 10 3rd Gen Woofer Replacement
你所需要的
  1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: 步骤 1 中的图像 1,2 Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: 步骤 1 中的图像 2,2
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Woofer Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
  3. Amazon Echo Show 10 3rd Gen Woofer Replacement: 步骤 3 中的图像 1,2 Amazon Echo Show 10 3rd Gen Woofer Replacement: 步骤 3 中的图像 2,2
    • Use an opening tool to pry up along the edge of the speaker.
    • Gently lift the woofer out of the device.
    • The woofer is connected to a cable so don't yank it out or you will damage the connector.
  4. Amazon Echo Show 10 3rd Gen Woofer Replacement: 步骤 4 中的图像 1,1
    • Tilt the woofer so the side with the cables is angled upwards.
    • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
    • For information on soldering, refer to the How to Solder and Desolder Connections guide.
  5. Amazon Echo Show 10 3rd Gen Woofer Replacement: 步骤 5 中的图像 1,1
    • After desoldering the three cables, lift the woofer out of the shell of the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 83
