简介
This guide will walk you through the replacement process for the display found within your Amazon Echo Show 10 3rd Gen device. The display is responsible for showing the UI of the device as well as allowing the user to control the device's settings and functions. If you are having problems with the device display not turning on, not responding to touch controls, or it is cracked or damaged, replacement may be necessary.
If possible, a restart of the device using the physical power button is recommended before replacement of the screen, since that may fix the issue without the need for disassembly. Please make sure to refer to the Amazon Echo Show 10 3rd Gen troubleshooting page before committing to replacement.
If the screen of your device is cracked or shattered, please refer to the guide linked here for information on preparing broken screens for replacement.
你所需要的
With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set aside.
