简介
Here is an Amana washer that had issues with the shift actuator. This was determined after running the automatic diagnostics. Replacement is straight forward with no pitfalls or difficulties.
你所需要的
To work on this replacement, you will need to gain access to the bottom. It is best to place the washer on its front. Place a few old blankets etc. so as not to scratch the front to much. Since I did a total rebuild on this washer, I had also removed the control panel. It was easier for me to place the washer upside down :-)
First the pulley cover has to be removed. It is attached via two 5/16 bolts
Use an electric screwdriver with a short extension and a 5/16 socket to remove the right screw,
2等其他人完成本指南。
