跳转到主内容
Alpine MRV-M500 Electrolytic Capacitor Replacement
你所需要的
  1. Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: 步骤 1 中的图像 1,3 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: 步骤 1 中的图像 2,3 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: 步骤 1 中的图像 3,3
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  2. Alpine MRV-M500 Electrolytic Capacitor Replacement: 步骤 2 中的图像 1,3 Alpine MRV-M500 Electrolytic Capacitor Replacement: 步骤 2 中的图像 2,3 Alpine MRV-M500 Electrolytic Capacitor Replacement: 步骤 2 中的图像 3,3
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Remove the circuit board from the case.
  3. Alpine MRV-M500 Electrolytic Capacitor Replacement: 步骤 3 中的图像 1,2 Alpine MRV-M500 Electrolytic Capacitor Replacement: 步骤 3 中的图像 2,2
    • Find the faulty capacitor.
    • Flip the board over and locate the corresponding pins.
    • If the faulty capacitor is one of the smaller ones, it may be too difficult to replace and replacing the circuit board itself may be easier.
    • Make sure that the capacitance and voltage rating of the new capacitor match that of the original.
  4. Alpine MRV-M500 Electrolytic Capacitor Replacement: 步骤 4 中的图像 1,1
    • Desolder the pins to remove the capacitor.
    • Solder the new capacitor into its place.
    • Make sure the polarity of the new capacitor matches the previous polarity.
结论
3等其他人完成本指南。
Eric Gaulke
于09/17/18注册
623 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,549
