跳转到主内容
Alpine MRV-M500 Circuit Board Replacement
你所需要的
  1. Alpine MRV-M500 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,3 Alpine MRV-M500 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 2,3 Alpine MRV-M500 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 3,3
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
  2. Alpine MRV-M500 Circuit Board Replacement: 步骤 2 中的图像 1,2 Alpine MRV-M500 Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  3. Alpine MRV-M500 Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Remove the circuit board from the case.
结论
To reassemble your device, follow these instructions in reverse order using the replacement circuit board.
4等其他人完成本指南。
Eric Gaulke
于09/17/18注册
623 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 35
总计 2,123
