跳转到主内容
加入维修社区 - 创建账户
AlphaSmart Pro Keyboard Replacement
你所需要的
    1. AlphaSmart Pro Keyboard Replacement, Separating Panels: 步骤 1 中的图像 1,3 AlphaSmart Pro Keyboard Replacement, Separating Panels: 步骤 1 中的图像 2,3 AlphaSmart Pro Keyboard Replacement, Separating Panels: 步骤 1 中的图像 3,3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      询问修复机器人
      添加评论
    2. AlphaSmart Pro Keyboard Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 1,3 AlphaSmart Pro Keyboard Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 2,3 AlphaSmart Pro Keyboard Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 3,3
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • Remove front panel from the motherboard.
      询问修复机器人
      添加评论
    3. AlphaSmart Pro Keyboard Replacement, Prepping Keyboard For Removal: 步骤 3 中的图像 1,3 AlphaSmart Pro Keyboard Replacement, Prepping Keyboard For Removal: 步骤 3 中的图像 2,3 AlphaSmart Pro Keyboard Replacement, Prepping Keyboard For Removal: 步骤 3 中的图像 3,3
      • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
      • Gently lift the keyboard from the rear panel.
      • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
      询问修复机器人
      添加评论
    4. AlphaSmart Pro Keyboard Replacement, Detaching keyboard Ribbon Cables: 步骤 4 中的图像 1,3 AlphaSmart Pro Keyboard Replacement, Detaching keyboard Ribbon Cables: 步骤 4 中的图像 2,3 AlphaSmart Pro Keyboard Replacement, Detaching keyboard Ribbon Cables: 步骤 4 中的图像 3,3
      • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
      • Pull the ribbon cable to remove it from the connector.
      • Repeat the exact steps above for the other ribbon cable.
      • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
      询问修复机器人
      添加评论
    5. AlphaSmart Pro Keyboard Replacement: 步骤 5 中的图像 1,1
      • Remove keyboard from motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G1
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 39
总计 1,266
