跳转到主内容
加入维修社区 - 创建账户
AlphaSmart Pro Individual Key Replacement
你所需要的
    1. AlphaSmart Pro Individual Key Replacement, Removing a Key: 步骤 1 中的图像 1,2 AlphaSmart Pro Individual Key Replacement, Removing a Key: 步骤 1 中的图像 2,2
      • Insert the plastic opening tool or spudger into the side of the key you wish to remove, and press downward on the far end of the tool to pry the key up.
      • You may also pry the key up by simply using your finger and/or fingernail, however, it is easier to use an opening tool.
      询问修复机器人
      添加评论
    2. AlphaSmart Pro Individual Key Replacement, The Spacebar Spring: 步骤 2 中的图像 1,1
      • If the key you are removing is the spacebar (like you see pictured here), you should find a single spring placed on one of two circular spots located one the right and left side underneath the key.
      • Remove the spring and place it to the side so it doesn't get lost.
      • It does not matter which of the two circular spots the spring is on.
      • There is only one spring per spacebar. If the spring is missing, don't worry — the spacebar will work fine without it — but it will work better when the spring is attached.
      询问修复机器人
      添加评论
    3. AlphaSmart Pro Individual Key Replacement, Removing Other Keys: 步骤 3 中的图像 1,1
      • If you wish to remove another key besides the spacebar, the same methods of removal apply.
      • You should hear a "popping" or "snapping" sound when the key has been removed.
      • Unlike the spacebar key, all the other keys do not have a spring.
      询问修复机器人
      添加评论
    4. AlphaSmart Pro Individual Key Replacement, Replacement: 步骤 4 中的图像 1,2 AlphaSmart Pro Individual Key Replacement, Replacement: 步骤 4 中的图像 2,2
      • To replace the key(s), simply align the center cylindrical post(s) with the center holes.
      • Use your index finger to press down on the middle of the key. You should hear it "click" into place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Katy Beth Culp
于10/13/14注册
1 声望
创作了2篇指南
团队
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G1
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 46
总计 2,054
