跳转到主内容
加入维修社区 - 创建账户
AlphaSmart Pro Front Panel Replacement
你所需要的
    1. AlphaSmart Pro Front Panel Replacement, Separating Panels: 步骤 1 中的图像 1,3 AlphaSmart Pro Front Panel Replacement, Separating Panels: 步骤 1 中的图像 2,3 AlphaSmart Pro Front Panel Replacement, Separating Panels: 步骤 1 中的图像 3,3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      询问修复机器人
      添加评论
    2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 1,2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 2,2
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • You are now able to separate the front panel from the back panel.
      询问修复机器人
      添加评论
    3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: 步骤 3 中的图像 1,3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: 步骤 3 中的图像 2,3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: 步骤 3 中的图像 3,3
      • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
      • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Nathan Smith
于10/13/14注册
22 声望
创作了2篇指南
团队
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G1
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 40
总计 627
