跳转到主内容
加入维修社区 - 创建账户
AlphaSmart Pro Display Screen Replacement
你所需要的
    1. AlphaSmart Pro Display Screen Replacement, Separating Panels: 步骤 1 中的图像 1,3 AlphaSmart Pro Display Screen Replacement, Separating Panels: 步骤 1 中的图像 2,3 AlphaSmart Pro Display Screen Replacement, Separating Panels: 步骤 1 中的图像 3,3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      询问修复机器人
      添加评论
    2. AlphaSmart Pro Display Screen Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 1,2 AlphaSmart Pro Display Screen Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 2,2
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • You are now able to separate the front panel from the back panel.
      询问修复机器人
      添加评论
    3. AlphaSmart Pro Display Screen Replacement, Removing Display Screen: 步骤 3 中的图像 1,3 AlphaSmart Pro Display Screen Replacement, Removing Display Screen: 步骤 3 中的图像 2,3 AlphaSmart Pro Display Screen Replacement, Removing Display Screen: 步骤 3 中的图像 3,3
      • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
      • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
      询问修复机器人
      添加评论
    1. AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: 步骤 4 中的图像 1,3 AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: 步骤 4 中的图像 2,3 AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      $3.99
      • To remove the small motherboard from the display screen, use the flat needle nose pliers or the angled tweezers to carefully bend the 12 metal tabs so that they can be pushed through the small slots.
      • You must also lift up the transparent tape that covers two of these tabs.
      • Separate the display screen and small motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Nathan Smith
于10/13/14注册
22 声望
创作了2篇指南
团队
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G1
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 76
总计 1,131
