跳转到主内容
加入维修社区 - 创建账户
Alienware X51 R2/R3 CPU Replacement
你所需要的
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): 步骤 1 中的图像 1,1
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
    询问修复机器人
    添加评论
  2. Alienware X51 R2/R3 CPU Replacement: 步骤 2 中的图像 1,1
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
    询问修复机器人
    添加评论
  3. Alienware X51 R2/R3 CPU Replacement: 步骤 3 中的图像 1,1
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
    询问修复机器人
    添加评论
  4. Alienware X51 R2/R3 CPU Replacement: 步骤 4 中的图像 1,1
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
    询问修复机器人
    添加评论
  5. Alienware X51 R2/R3 CPU Replacement: 步骤 5 中的图像 1,1
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 52
总计 3,244
