跳转到主内容
加入维修社区 - 创建账户
Alienware X51 R1/R2/R3 RAM Replacement
你所需要的
  1. Alienware X51 R1/R2/R3 RAM Replacement, Remove Panel Screw: 步骤 1 中的图像 1,1
    • First, turn the computer so you can see the rear panel. Remove the small screw to the right (or above, if the system is on its side) of the audio jacks.
    • Once the screw is removed, use both hands to push the side panel down and towards the front of the case.
    询问修复机器人
    添加评论
  2. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect LED Control Cable: 步骤 2 中的图像 1,1
    • Lift the side panel off, and gently flip it over the top of the system, being careful not to break the LED control cable. Unplug its connector and set the case panel to the side.
    询问修复机器人
    添加评论
  3. Alienware X51 R1/R2/R3 RAM Replacement, Remove Fan Screws: 步骤 3 中的图像 1,1
    • Next, remove the screws securing the plastic air re-director (not shown in picture) to the fan, and gently lift it out of the case. Set aside and move to the next step.
    询问修复机器人
    添加评论
  4. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect/Remove the DVD Drive: 步骤 4 中的图像 1,1
    • Unplug the SATA cable at the base of the DVD drive circled in blue. This cable will have a lot of tension on it, but do not worry. Just be careful not to yank on it too much.
    • You will then unscrew the screw securing the DVD drive to the case (circled in red). Once the screw is removed, remove the DVD drive and set to the side.
    询问修复机器人
    添加评论
  5. Alienware X51 R1/R2/R3 RAM Replacement: 步骤 5 中的图像 1,1
    • Now, push the white latch (circled in red) DOWN and pull the ram card straight up to a ~45 degree angle. Pull up and out, towards the latch side, and set aside.
    询问修复机器人
    添加评论
  6. Alienware X51 R1/R2/R3 RAM Replacement, Insert New Ram Card: 步骤 6 中的图像 1,1
    • You will insert the new DIMM. Push the side opposite to the latch in first, being sure that the notch in the connector matches the location on the ram DIMM.
    • Insert at a ~45 degree angle and push straight down into the socket, being sure that the latch clicks.
    • DO NOT FORCE THE DIMM IN. Rotate the card and try again if the card will not go into the port.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Daniel Niles
于02/12/16注册
163 声望
撰写一个指南
团队
Pasco Hernando, Team 5-6, Prince Winter 2016 Pasco Hernando, Team 5-6, Prince Winter 2016 的会员
PHSC-PRINCE-W16S5G6
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 56
总计 7,065
