跳转到主内容
加入维修社区 - 创建账户
Alienware Pro Wireless Gaming Mouse Optical Lens Replacement
你所需要的
  1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Feet: 步骤 1 中的图像 1,3 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Feet: 步骤 1 中的图像 2,3 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Feet: 步骤 1 中的图像 3,3
    • Flip the mouse over so the bottom is facing up..
    • Use an opening pick to gently peel the mouse foot off the bottom case.
    • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
    询问修复机器人
    添加评论
  2. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 2 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 2 中的图像 2,2
    • Peel and remove the other mouse foot.
    询问修复机器人
    添加评论
  3. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
    询问修复机器人
    添加评论
  4. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 4 中的图像 1,3 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 4 中的图像 2,3 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 4 中的图像 3,3
    • Use your hands or a spudger to separate the bottom and top of the mouse.
    • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
    • You may hear a cracking sound when the clips are released.
    询问修复机器人
    添加评论
  5. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 5 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 5 中的图像 2,2
    • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
    询问修复机器人
    添加评论
  6. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 6 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 6 中的图像 2,2
    • The battery is glued to the case.
    • Use an opening tool or spudger to loosen the adhesive under the battery.
    • Remove the battery.
    询问修复机器人
    添加评论
  7. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Side Button: 步骤 7 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Side Button: 步骤 7 中的图像 2,2
    • Pinch the upper part of the ribbon cable.
    • Pull the ribbon cable gently to detach it from the socket on the motherboard.
    • Make sure the ribbon line is facing the correct direction when reassembling the controller.
    询问修复机器人
    添加评论
  8. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 8 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 8 中的图像 2,2
    • Lift the side button panel from the plastic frame.
    询问修复机器人
    添加评论
  9. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Scroll Wheel: 步骤 9 中的图像 1,3 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Scroll Wheel: 步骤 9 中的图像 2,3 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Scroll Wheel: 步骤 9 中的图像 3,3
    • Hold the scroll wheel encoder steady and gently pull the scroll wheel to the right to remove it.
    • Only light force is needed—be gentle to avoid damaging nearby parts.
    询问修复机器人
    添加评论
  10. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws at the bottom of the motherboard.
    询问修复机器人
    添加评论
  11. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 11 中的图像 1,1
    • Gently pull the side clip away from the motherboard to release it from the plastic frame.
    • Use a spudger to release the board from the clips if that is easier.
    询问修复机器人
    添加评论
  12. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 12 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 步骤 12 中的图像 2,2
    • Bend the front nose of the mouse body to release the motherboard.
    • Remove the motherboard from the bottom case.
    询问修复机器人
    添加评论
  13. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Optical Lens: 步骤 13 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Optical Lens: 步骤 13 中的图像 2,2
    • On the bottom of the motherboard, remove the clear plastic lens.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 136
