跳转到主内容
加入维修社区 - 创建账户
Alienware Pro Wireless Gaming Mouse Battery Replacement
你所需要的
  1. Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: 步骤 1 中的图像 1,3 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: 步骤 1 中的图像 2,3 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: 步骤 1 中的图像 3,3
    • Flip the mouse over so the bottom is facing up..
    • Use an opening pick to gently peel the mouse foot off the bottom case.
    • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
    询问修复机器人
    添加评论
  2. Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 2 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 2 中的图像 2,2
    • Peel and remove the other mouse foot.
    询问修复机器人
    添加评论
  3. Alienware Pro Wireless Gaming Mouse Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
    询问修复机器人
    添加评论
  4. Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 4 中的图像 1,3 Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 4 中的图像 2,3 Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 4 中的图像 3,3
    • Use your hands or a spudger to separate the bottom and top of the mouse.
    • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
    • You may hear a cracking sound when the clips are released.
    询问修复机器人
    添加评论
  5. Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 5 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 5 中的图像 2,2
    • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
    询问修复机器人
    添加评论
  6. Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 6 中的图像 1,2 Alienware Pro Wireless Gaming Mouse Battery Replacement: 步骤 6 中的图像 2,2
    • The battery is glued to the case.
    • Use an opening tool or spudger to loosen the adhesive under the battery.
    • Remove the battery.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Matt Seay
于09/29/25注册
401 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 256
