跳转到主内容
加入维修社区 - 创建账户
Alienware M17x RAM Replacement
你所需要的
    1. Alienware M17x RAM Replacement, Battery: 步骤 1 中的图像 1,2 Alienware M17x RAM Replacement, Battery: 步骤 1 中的图像 2,2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      询问修复机器人
      添加评论
    2. Alienware M17x RAM Replacement: 步骤 2 中的图像 1,1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      询问修复机器人
      添加评论
    3. Alienware M17x RAM Replacement: 步骤 3 中的图像 1,1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      询问修复机器人
      添加评论
    4. Alienware M17x RAM Replacement: 步骤 4 中的图像 1,2 Alienware M17x RAM Replacement: 步骤 4 中的图像 2,2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      询问修复机器人
      添加评论
    1. Alienware M17x RAM Replacement, RAM: 步骤 5 中的图像 1,2 Alienware M17x RAM Replacement, RAM: 步骤 5 中的图像 2,2
      • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
      询问修复机器人
      添加评论
    2. Alienware M17x RAM Replacement: 步骤 6 中的图像 1,2 Alienware M17x RAM Replacement: 步骤 6 中的图像 2,2
      • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
      • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
      询问修复机器人
      添加评论
    3. Alienware M17x RAM Replacement: 步骤 7 中的图像 1,1
      • Remove the bottom RAM card in a similar manner.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 874
