跳转到主内容
加入维修社区 - 创建账户
Alienware M17x Motherboard Replacement
你所需要的
  1. Alienware M17x Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Alienware M17x Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    询问修复机器人
    添加评论
  2. Alienware M17x Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    询问修复机器人
    添加评论
  3. Alienware M17x Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    询问修复机器人
    添加评论
  4. Alienware M17x Motherboard Replacement: 步骤 4 中的图像 1,2 Alienware M17x Motherboard Replacement: 步骤 4 中的图像 2,2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    询问修复机器人
    添加评论
  5. Alienware M17x Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
    • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
    • Twelve 5.5 mm Phillips #0 main frame screws.
    • Six 3.5 mm Phillips #0 fan screws.
    • Four 3.5 mm Phillips #0 internal compartment screws.
    • Eight 3.5 mm Phillips #0 Hard Drive screws.
    • Four 3.5 mm Phillips #0 CD Drive screws.
    • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
    询问修复机器人
    添加评论
  6. Alienware M17x Motherboard Replacement: 步骤 6 中的图像 1,3 Alienware M17x Motherboard Replacement: 步骤 6 中的图像 2,3 Alienware M17x Motherboard Replacement: 步骤 6 中的图像 3,3
    • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the computer.
    询问修复机器人
    添加评论
  7. Alienware M17x Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove five 3.5 mm Phillips #0 screws from the motherboard.
    • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
    • Lift the motherboard at an angle and remove it from the computer base.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 2,468
